StarPort Fibre Channel over Ethernet Initiator
StarPort FCoE Initiator
Fibre Channel over Ethernet (FCoE) is an encapsulation of Fibre Channel packets over Ethernet networks. This allows Fibre Channel to leverage 10 Gigabit Ethernet networks while preserving the Fibre Channel protocol.FCoE maps Fibre Channel natively over Ethernet while being independent of the Ethernet routing scheme.
StarPort fully implements Fibre Channel-over-Ethernet client side protocol enabling you to connect to remote storage appliances such as those developed by Qlogic and Cisco. StarPort FCoE (Fibre Channel-over-Ethernet) support enables connectivity to remote storage devices over a standard Ethernet network, regardless of where the device resides. With StarPort and Fibre Channel-over-Ethernet you can gain full access to a device, as though the device was installed on a local machine.
FCoE (FibreChannel-ver-Ethernet) Initiator
