Free Webinar
March 7 | 11am PT / 2pm ET
Do you dream of the fastest data transfer rate?
See how to ensure max RDMA network performance!
Speaker: Vladyslav Savchenko, Pre-Sales Engineer, StarWind
StarWind Virtual SAN® System Requirements
Published: May 31, 2018
INTRODUCTION
This document describes system requirements for StarWind Virtual SAN, including the full information about the recommended CPU, RAM, storage, network bandwidth, and operating systems. The document also covers the system requirements for deploying StarWind VSAN as a virtual machine.
Additionally, the requirements for the Asynchronous replication are specified.
The technical paper is intended for virtualization administrators and StarWind users who are planning to deploy StarWind VSAN and need technical details to proceed. A full set of up-to-date technical documentation can always be found here, or by pressing the Help button in the StarWind Management Console.
For any technical inquiries please visit our online community, Frequently Asked Questions page, or use the support form to contact our technical support department.
CPU
CPU: Intel Xeon E5620 (or higher) or equivalent AMD Opteron
With 75% of server workloads being virtualized, virtualization is just getting started. VDI and SMB clouds have just started to emerge and will grow rapidly in the next few years. As IT is moving forward at an ever-increasing pace, datacenters are becoming hyperconverged.
The minimum recommended CPU is Intel Xeon E5620 or equivalent. Intel Xeon X5660 or equivalent can be used in order to maximize the performance.
RAM
RAM: 4GB is the minimum.
RAM amount that should be installed on a server that is running StarWind Virtual SAN. In case of implementing StarWind High Speed caching, an appropriate RAM amount should be installed additionally. The cache-dedicated RAM amount should be equal or higher than the one reserved for iSCSI targets caching.
In-line deduplication with LSFS requires 7.6 GB of RAM per 1 TB of deduplicated storage.
IMPORTANT NOTICE: Always reserve at least 4 GB RAM for Windows internal processes and the StarWind Virtual SAN engine.
Storage
• Hardware RAID controller is highly recommended
• StarWind Virtual SAN supports Microsoft Storage Spaces
• Software RAID implementations are NOT supported
Depending on the storage requirements, the most appropriate RAID configuration can be selected. StarWind recommendations for the proper HA storage design are:
• RAID 10 for SAS or SATA hard drives
• RAID 1, 5, 6, 10 for SAS or SATA SSDs
RAID 5, 6, 50, 60 can be considered for a backup/VTL environment with mostly sequential workloads, where the best write performance is not a critical requirement and the main goal is to achieve the maximum storage efficiency. In order to receive an additional information regarding the particular storage design, please contact StarWind Support.
The minimum requirement for StarWind installation and logging is 3 GB of disk space. The StarWind virtual disks must reside on the separate partition from StarWind installation.
Networks
Minimum of 2 x 1GbE physical NICs
The minimum supported bandwidth is 1 GbE. In case of an intensive workload, the scaling to the 10 GbE or 40 GbE infrastructure should be considered. In order to maximize the SAN environment performance, it is highly recommended to use 9K Jumbo frame capable network equipment.
StarWind Synchronization network has a prerequisite of both NIC (preferred) and switch (if used) fault tolerance measures. The use of STP (Shielded twisted pair) CAT6 (or higher) cable is required for the Synchronization Network for both crossover and server-switch connections.
Network latency requirements
Maximum Synchronization network latency should not exceed 5 ms.
Network latency higher than 5 ms may lead to the HA performance degradation.
It is recommended to consult on long-distance cross-datacenter deployments with StarWind Technical Engineers per case basis.
Supported Operating Systems
• Microsoft Windows Server 2008 R2 (partial support)
• Microsoft Windows Server 2012
• Microsoft Windows Server 2012 R2
• Microsoft Windows Server 2016
Supported Microsoft Windows Server GUI-less editions
• Windows Server Core 2008 R2 (partial support)
• Windows Server Core 2012
• Windows Server Core 2012 R2
• Hyper-V Server 2008 R2 (partial support)
• Hyper-V Server 2012
• Hyper-V Server 2012 R2
• Hyper-V Server 2016
IMPORTANT NOTICE: The use of Windows Server Core or Microsoft Hyper-V Server as a base OS is incompatible with StarWind Management Console local installation. In this case, the StarWind Management console should be installed on any other computer. Please note that for remote management, port 3261 has to be open in both machines’ firewalls.
Microsoft Windows Desktop editions compatible with StarWind Management Console
• Windows 7
• Windows 8
• Windows 8.1
• Windows 10
System requirements for deploying StarWind as a virtual
machine:
CPU. 4 virtual processors with 2 GHz reserved is the minimum requirement to ensure the proper functioning of VSA.
Network Settings. 2 NIC ports dedicated as separate virtual switches is the minimum requirement for StarWind synchronization and iSCSI traffic. The recommended minimal bandwidth is 1 GbE. In case of an intensive workload, the scaling to a 10 GbE or higher should be considered.
Infrastructure. Supported vSphere version: 5.x and later.
IMPORTANT NOTICE: When using StarWind with synchronous replication feature inside of a Virtual Machine, it is recommended not to make backups and snapshots of the Virtual Machine with StarWind Service which could pause the StarWind Virtual Machine.
Pausing the Virtual Machines while StarWind service under load may lead to split-brain issues in devices with synchronous replication and data corruption.
For specific recommendations, please contact StarWind Support.
RAM. For storage workload handling, the primary storage system must allocate 128 MB of RAM additionally. The disaster recovery location must correspond the LSFS device requirements specified here:
https://www.starwindsoftware.com/resource-library/lsfs-container-technical-description
IMPORTANT NOTICE: The requirement is applied only to StarWind-related RAM expenses. The memory for OS, hypervisor, and other applications should be sized separately.
Bandwidth. The minimal required throughput is 10 Mbps. It is recommended to use the data link that is physically capable of transmitting the replicated amount of data within the desired backup window time.
Physical Storage Considerations. The performance of the drive storing the primary node replication journal must be higher or equal to the maximum write throughput of the production storage array. The measurement should be held under “8MB block size 100% sequential write” pattern. The reserved free space of the journal disk must exceed the amount of data written to the production storage array within the time frame between the snapshots, plus additional 25%.
