Scalable Storage Guide: Architecture, Concepts, and Examples
  • April 8, 2026
  • 25 min read
Gartner projects data center spending will clear $650B in 2026 a 31.7% jump year-over-year. Storage is a big part of that number, but budget alone doesn’t solve the underlying problem: a system can be large and still fall apart the moment demand shifts. An aggressive backup window that bleeds into business hours, an analytics job nobody planned for, a sudden spike in random 4K writes – any of these can expose gaps in a storage design that looked fine on paper six months ago.
This article covers what scalable storage means in practice, how the core mechanics work, and how to think through the scale-up vs. scale-out decision before you’re making it under pressure.
What is scalable storage?
Scalable storage is a storage architecture that grows capacity and performance with predictable operational impact – using scale-up, scale-out, or a combination of both.
Today, the word “scalable” gets thrown around loosely. Adding drive shelves to a controller that’s already maxed out on IOPS doesn’t count. Real scalability means four things move together:
  • Usable capacity after protection overhead
  • Latency under actual production load (not vendor benchmark conditions)
  • Resilience when hardware fails mid-operation
  • Manageability as the footprint grows
When any one of these falls behind the others, you end up with a system that looks healthy on the capacity dashboard but delivers inconsistent performance to the workloads that matter.
How it works under the hood
Scalable storage systems take heterogeneous physical resources and present them as a single logical service. That abstraction holds up under growth because of a few core mechanics working together.
Pooling
Aggregates disks and nodes into shared namespaces or volumes. It’s primarily an operational convenience – scalability can be achieved without it, but managing dozens of independent storage silos is nobody’s idea of a good time.
Data placement distributes workload across nodes so no single controller becomes a bottleneck. This is where many storage designs quietly fail. A cluster can look perfectly balanced on capacity metrics while showing wildly uneven latency because placement isn’t accounting for I/O density per node.
Data protection
Handled through either replication or erasure coding. Replication is simple – keep two or three full copies, but the space overhead is steep (either 50% or ~33,33%).
Erasure coding splits data into fragments with distributed parity, which is far more space-efficient at scale, but is significantly less performant in terms of IOPS and throughput. For example, Ceph’s recent FastEC implementation (released in Tentacle v20.2.0, November 2025) improved small read/write performance on erasure-coded pools by 2-3x, making the trade-off more favorable than it used to be. With a 6+2 EC profile, you get roughly 50% of replication’s performance at 33% of the space cost: not perfect, but works good enough for environments where cheap capacity is the priority.
The rebuild cost is the part that doesn’t make it into most marketing materials. When a node fails in an erasure-coded pool, the system has to read fragments from every surviving node, recalculate parity, and write new fragments – all while serving production I/O. Systems that spread fragments independently across disks can parallelize this across many drives, which helps enormously, but the I/O tax during rebuild is real and needs to be planned for.
Rebalancing
The operational reality nobody talks about enough. When you add hardware, the system redistributes existing data across the new nodes. NetApp’s StorageGRID documentation explicitly warns that EC rebalance procedures decrease the performance of both ILM operations and client operations while running, and recommends only running them when existing nodes are above 80% full and you can’t add enough new nodes to absorb future writes naturally. That’s not a theoretical concern – it’s documented operational guidance from a vendor who’s seen what happens when people rebalance casually.
The control plane
Orchestrates all of it: health checks, configuration, automated recovery. Its reliability determines whether a component failure automatically generates a maintenance ticket or, at least, meaningful logs, system events and alerts for further troubleshooting.
Scale-up vs. scale-out vs. hybrid
The architecture choice you make early shapes every expansion decision that follows.
Scale-up vs Scale-out
Figure 1: Storage growth models compared: scale-up hits a hardware ceiling, scale-out adds independent nodes across a shared network fabric.
Scale-up (vertical)
You grow by making the existing system larger: more RAM, faster controllers, additional drive shelves. It’s operationally simple, and for latency-sensitive workloads like core OLTP databases, keeping data on a single controller namespace still makes sense. There’s a reason high-frequency trading firms and critical database workloads still run on big iron.
The constraint is physical. Every chassis and controller has a ceiling, and when you hit it, your options narrow to buying a new system and migrating data – exactly the scenario scalable storage is supposed to prevent. The upgrade cycle also tends to be forklift: you’re not adding a little capacity, you’re replacing the whole controller pair and hoping the data migration completes during the maintenance window.
Scale-out (horizontal)
You grow by adding nodes to a cluster. Each node brings its own compute, storage, and network bandwidth, so capacity and performance grow together in a well-designed system.
This model handles unpredictable growth better than the alternatives: large VM fleets, unstructured data, object storage at petabyte scale. But scale-out has its own failure modes that vendors under-discuss. The network becomes the critical path – internal cluster traffic can saturate switch fabric before storage media is anywhere near its limit. Metadata hot spots are a known issue in distributed systems where a small number of directories or buckets handle disproportionate traffic. And the operational complexity is genuine: more nodes means more firmware versions to track, more failure domains to reason about, and more rebalancing events to schedule.
Hybrid
Most mid-market deployments end up here by necessity. You scale up within nodes first (adding drives or RAM), then scale out by adding nodes once you hit internal chassis limits. This works well for virtualization stacks and edge/ROBO deployments where growth comes in controlled increments.
The failure mode is planning gaps. Organizations that focus exclusively on TB targets and ignore controller throughput limits end up with systems that have plenty of space but can’t sustain the IOPS their workloads actually need. If your capacity planning spreadsheet doesn’t have a column for controller CPU utilization and front-end port bandwidth, you’re only seeing half the picture.
ModelHow You GrowBest FitWhere It Breaks Down
Scale-up Expand one system Low-latency, single-namespace workloads Controller and chassis ceilings; forklift upgrades
Scale-out Add nodes to cluster Unstructured growth, shared services, petabyte scale Network fabric saturation, metadata hot spots
Hybrid Larger nodes, then more nodes Phased growth, virtualization stacks Overlooked controller limits as TB count grows
Practical benefits
The case for scalable storage comes down to avoiding the operational situations that consume engineering time and unplanned budget.
Pay-as-you-grow means capital expenditure tracks actual demand rather than worst-case projections from three years ago. With infrastructure cost scrutiny increasing everywhere, the ability to expand in $20-50K increments instead of $200K forklift upgrades changes the budgeting conversation entirely.
Fewer migrations are the direct result of building on a platform that expands in place. Anyone who’s lived through a storage migration knows the reality: months of planning, weekend maintenance windows, application-level validation afterward, and at least one thing that doesn’t come back up cleanly. Designing to avoid that cycle is worth real money over a five-year infrastructure lifecycle.
Performance that actually scales with capacity is the sign of a well-designed architecture. In a many-to-many system, adding nodes should increase aggregate throughput and support more concurrent clients. If adding a node only adds TBs without improving IOPS, the architecture is bottlenecked somewhere – usually the network or the metadata layer.
Node-level failure tolerance changes the operational posture significantly. When a single node failure is a hardware replacement ticket instead of a production incident, your on-call engineers sleep better and your SLAs get easier to maintain.
Workload fit
Different storage models suit different I/O profiles. Getting this wrong usually shows up as a performance problem that gets misdiagnosed as a capacity problem.
Backup and archive workloads involve large sequential writes with long retention. S3-compatible object storage with immutability policies is the standard fit, and immutability is increasingly non-negotiable for ransomware protection. Don’t put these workloads on your primary block storage – the sequential write patterns will interfere with the random I/O your production VMs need.
File services at scale – many users, many small files – puts heavy pressure on metadata operations. This is where scale-out NAS systems designed for high metadata throughput earn their cost. A block-oriented or object-oriented platform technically stores files fine, but the metadata overhead will kill performance once you’re past a few million objects per namespace.
Virtualization and edge compute generates high-pressure, largely random I/O. Block storage or hyperconverged infrastructure is the right fit. Object storage is architecturally wrong for this workload, regardless of what any vendor’s marketing page suggests.
Analytics and data lakes need high parallel read throughput and support for large sequential scans. The common pattern is object storage for the lake tier with a high-performance file system or caching layer in front of compute for active workloads. Separation of storage and compute works well here because you can scale query engines independently of the data footprint.
What to measure before you buy (and after)
Scalable storage systems run into physics eventually. Throughput is bounded by network bandwidth, rebalancing operations consume real I/O capacity, and rebuild times after failures depend on how much data needs to move. Planning around these constraints rather than discovering them post-purchase is the difference between a system that scales gracefully and one that surprises you.
What to MeasureWhy It Matters
Read/write ratio and block size distribution A spec tested on sequential 128K reads tells you almost nothing about 4K random write performance. Capture your actual I/O profile before evaluating platforms.
Rebalancing throughput Expansion operations run concurrently with production workloads. Know how fast data moves and what the I/O tax is so you can schedule expansions outside peak hours.
Failure domains Whether a failure domain is a disk, host, rack, or site determines the blast radius of any single failure event. Design for the largest domain you can tolerate losing.
p99 latency under load Averages hide the outliers that users actually experience. The 99th percentile tells you what the worst-case VM or query is seeing during peak hours.
Controller CPU and port utilization The metric most often missing from capacity plans. A controller at 85% CPU will bottleneck before you fill the drives behind it.
One rule applies across all architectures: don’t operate near capacity limits. The last 20% of usable space is where placement algorithms degrade, rebalancing slows, and performance becomes unpredictable. Running at 70-75% utilization is a reasonable ceiling for most production workloads. Some popular storage vendors even recommend avoiding EC rebalance unless nodes exceed 80% – which means if you’re already at 80%, you’ve waited too long to expand.
Platform options
Cloud-managed storage (AWS S3/EFS/EBS, Azure Blob/Files/Disks, GCP Storage/Filestore/PD) offers the lowest operational overhead since the provider handles hardware and service management. The trade-offs are real: performance can throttle near published limits, egress costs accumulate quickly with heavy data movement, and matching access patterns to the right storage class requires ongoing attention. Separating storage and compute in the cloud lets you scale processing independently, but the bandwidth between compute and storage tiers isn’t unlimited and can become the bottleneck in analytics-heavy workloads.
On-premises platforms give tighter control and predictable data locality at the cost of owning the full operational stack: expansions, compatibility testing, upgrade discipline, and rebuild planning. Hyperconverged platforms like vSAN make the scale-out model explicit – adding hosts adds compute and storage together, with fairly automated performance tuning. Ceph offers similar scale-out capabilities but requires more manual tuning to reach optimal performance; the trade-off is full open-source flexibility versus operational simplicity.
S3-compatible object storage bridges on-premises deployments and cloud API compatibility. A word of caution here: MinIO, which was a popular choice for self-hosted S3, effectively entered maintenance mode in late 2025 when a quiet README commit announced it would no longer accept new changes. Key features like SSO, LDAP, and OIDC had already moved to the paid edition, and pre-built binaries were discontinued for community users. If you’re evaluating S3-compatible platforms, factor in the long-term licensing trajectory, not just today’s feature set. Ceph’s RADOS Gateway (RGW) is the most established open-source alternative.
DataCore covers both ends of the on-prem spectrum. StarWind Virtual SAN delivers HA shared storage for SMB and ROBO clusters on commodity hardware through synchronous replication between as few as two nodes. DataCore Swarm is a scale-out S3-compatible object storage platform that pools standard x86 servers into a self-managing cluster, using only 5% of disk capacity for system overhead, targeting petabyte-scale active archives, immutable backup, and multi-tenant storage environments.
Platform Deployment Model Best For
AWS (S3/EFS/EBS) Cloud Managed Mixed object, file, and block workloads
Azure (Blob/Files/Disks) Cloud Managed Object storage, SMB/NFS files, VM disks
Google Cloud (GCS/Filestore) Cloud Managed Object storage, NFS files, VM block
Dell PowerScale On-prem Scale-out NAS Large file services, content workflows
NetApp ONTAP On-prem Scale-out NAS Mature file and block services
VMware vSAN On-prem HCI Virtualization-centric growth
MinIO On-prem Scale-out S3 S3 workloads (evaluate licensing carefully)
Ceph (RGW) On-prem Scale-out S3 Open-source object, optional block and file
Scality (via HPE) On-prem Scale-out S3 Backup targets, multi-tenant object storage
StarWind Virtual SAN On-prem 2-node HA SMB/ROBO HA shared storage
DataCore Swarm On-prem Scale-out S3 Archives, immutable backup, data lakes
Scalable storage is an architecture decision, not a product category. The key is matching the growth model to how your workload actually behaves and being honest about where the limits are before you hit them.
Scale up when you need deterministic latency on a single, high-intensity workload and can accept the eventual ceiling. Scale out when growth is unpredictable or when you’re managing shared services at any meaningful size. Hybrid covers most of the middle ground, particularly for virtualization-centric environments, as long as you’re tracking controller headroom alongside raw capacity.
Whatever model you choose: watch your p99 latency, not just your averages, and keep utilization below 75%. The behavior of a storage system at 90% capacity is rarely what anyone tested in the proof of concept.
Hey! Found Ivan’s insights useful? Looking for a cost-effective, high-performance, and easy-to-use hyperconverged platform?
Taras Shved
