Best On-Premises Storage Solutions 2026
  • March 31, 2026
  • 35 min read
Every organization has workloads that don’t belong in the cloud – whether that’s a compliance requirement, an AI pipeline where egress fees killed the economics, or a predictable workload that simply costs less on your own hardware. Cloud repatriation has become a real trend: industry surveys suggest a significant share of enterprise CIOs are evaluating moving at least some workloads back on-premises, though the specific numbers, as always – depend heavily on how the question is framed. Nevertheless, the question for many IT teams has changed from “should we go on-prem” to “which platform.”
This guide covers the popular on-prem storage solutions in detail – architecture, performance, ideal workloads, and cost – so you can make a confident decision.
What on-premises storage is
On-premises storage means infrastructure physically located in your own facilities (data centers, colocation cages, or edge sites) owned and operated by your team. You control the hardware, the network path, the encryption keys, and the lifecycle. Nothing passes through a public cloud provider’s infrastructure unless you explicitly route it there.
On-premises vs Cloud simplified scheme
Figure 1: On-premises vs Cloud simplified scheme
On-premises deployments usually follow one of three architectural models:
Disaggregated (traditional) keeps compute and storage as fully separate layers, purchased and managed independently – think standalone SAN arrays connected to standalone servers.
Converged (CI, e.g., VCE Vblock, FlexPod) pre-integrates compute, storage, networking, and virtualization into a validated package. The components are still physically separate, but they’re engineered, tested, and supported as a unit, which cuts deployment time and finger-pointing between vendors.
Hyperconverged (HCI) collapses compute and storage onto every node in a scale-out cluster – less architectural flexibility, significantly less operational overhead.
On top of any of these architectures, storage is accessed three ways:
Block: raw block devices over Fibre Channel, iSCSI, or NVMe-oF. Ideal for transactional databases requiring sub-millisecond latency: Oracle, SQL Server, SAP HANA.
File: shared filesystem over NFS or SMB. The right choice for collaboration workloads, AI training pipelines, and media production workflows moving large sequential files.
Object: HTTP/S3 interface for massive flat repositories – backups, archives, data lakes for ML. Object storage scales cheaply on commodity hardware but is structurally unsuited to low-latency transactional access. It’s a fundamentally different paradigm from SAN or NAS, not a replacement for either.
When to choose on-premises over cloud
Before evaluating any vendor, the more important question is whether on-premises is actually the right call for your specific workload. Here are the scenarios where on-premises wins in 2026:
Data sovereignty and compliance
GDPR, HIPAA, PCI DSS, and sector mandates require auditable physical data residency. Healthcare, finance, government, and defense are the obvious cases.
Performance-critical workloads
Sub-millisecond latency for real-time trading, in-memory databases, HPC simulation, and edge AI inference. Fintech, automotive, and manufacturing environments where network jitter to a cloud region is unacceptable.
Cost optimization for stable workloads
Flat capacity and IOPS profiles reach break-even against cloud relatively quickly; after that, marginal cost approaches zero. Media, retail, and enterprise SaaS backends with predictable growth fit here.
Large datasets with egress sensitivity
Storing 1 PB on Azure Hot tier alone costs roughly $20,000/month (at ~$0.02/GB/month) – about $1.2M over five years – and that’s before retrieval, egress, and API fees. Cool and Archive tiers are substantially cheaper, but if you’re repeatedly accessing petabyte-scale data for processing (genomics pipelines, seismic analysis, video rendering), the access costs on cheaper tiers eat the savings. On-premises eliminates egress fees entirely.
Legacy application integration
Apps with Fibre Channel dependencies, proprietary APIs, or block device semantics that would require a full rewrite to run in the cloud. Manufacturing ERP, utilities SCADA, and mainframe environments fall here.
Offline and edge operations
Mission-critical systems that must run without WAN connectivity – naval/military deployments, remote industrial sites, field research stations.
If your team lacks storage expertise or you need to move fast, starting in the cloud makes sense. The question isn’t which model wins universally – it’s which workloads belong where.
How to choose
  1. Start with your workload profile. Define what you need: IOPS (random or sequential?), latency requirements (microseconds, milliseconds, or throughput-bound?), capacity growth trajectory, protocol requirements. The architecture selection – SAN, scale-out NAS, or object – should be settled before you evaluate specific vendors. Choosing a NAS platform for a transactional database workload is a mistake no vendor feature list will fix.
  2. Map protocols to applications. Map every application to the storage protocol it requires. Avoid platforms where your primary workload needs a gateway or translation layer. NetApp ONTAP and HPE Alletra MP offer the broadest native multi-protocol coverage. If your environment requires NFS, SMB, iSCSI, NVMe-oF, and S3 simultaneously, that narrows the shortlist fast.
  3. Get serious about data protection requirements. Zero-RPO active-active replication (Pure ActiveCluster, StarWind Synchronous Replication, IBM HyperSwap, HPE Peer Persistence) for Tier-1 workloads. Async replication for Tier-2. Verify that ransomware immutability is out-of-band – a compromised administrator account shouldn’t be able to delete the snapshots. SafeMode (Pure) and Safeguarded Copy (IBM) both meet this bar. Not every platform does.
  4. Match complexity to team size. This is the factor organizations most consistently underestimate. Lower operational overhead: StarWind, FlashArray, HyperStore. Medium: ONTAP, PowerScale, Alletra, SANsymphony. Higher: FlashSystem. If your storage team is one or two people, a platform that requires deep expertise to tune and maintain will cost you in ways the vendor quote doesn’t show.
  5. Run the proof-of-concept with your actual workloads. Synthetic benchmarks measure what the array can do under ideal conditions. They don’t tell you how it performs under your I/O mix, with your data characteristics, and with your failure patterns. Before committing, run representative production workloads against the finalists.
Top on-premises storage solutions
The solutions below are grouped by category – enterprise storage arrays, object storage, and software-defined storage – because these are fundamentally different product types with different architectures, buyers, and evaluation criteria. Comparing an all-flash SAN array to an S3-compatible object store in a flat list is like comparing a sports car to a cargo ship: both move things, but the selection criteria have almost nothing in common.
Enterprise storage arrays
These are purpose-built hardware platforms from major storage vendors. They ship as integrated appliances with vendor-supported hardware, firmware, and management software. If you’re running traditional enterprise workloads – databases, virtualization, ERP – this is the category you’re evaluating.
Unified storage (block + file)
Unified arrays serve both block (SAN) and file (NAS) workloads from a single platform, reducing the number of separate systems to manage. The tradeoff is that a unified array rarely matches the performance of a purpose-built SAN or purpose-built NAS at their respective specialties – but for environments running both workload types, the operational simplification is often worth that tradeoff.
NetApp ONTAP
ONTAP is the operating system that runs across NetApp’s hardware lineup. AFF (All Flash FAS) handles unified SAN and NAS from a single cluster. ASA (All SAN Array) is purpose-built for block-only workloads and drops the NAS overhead. All variants support NFS, SMB, iSCSI, NVMe-oF, FC, and S3 natively – the broadest multi-protocol coverage on this list.
Replication, cloning, tiering, and ransomware protection are included but each is a separate license – ask for the full licensing matrix before you commit, because the base price and the fully-licensed price can be very different numbers. Organizations that get full value from ONTAP typically have certified administrators on staff.
The NetApp ONTAP System Manager dashboard showing cluster health and storage utilization
Figure 2: The NetApp ONTAP System Manager dashboard showing cluster health and storage utilization
Protocols NFS, SMB, iSCSI, NVMe-oF, FC, S3
Key features SnapMirror Sync (zero-RPO replication), FlexClone instant writable clones, Autonomous Ransomware Protection, FabricPool cloud tiering to AWS/Azure/GCP, BlueXP unified management
Best for SAP HANA and Oracle RAC, VMware vSphere, Kubernetes persistent storage, AI training and inference pipelines, enterprise NAS consolidation, hybrid-cloud tiering
HPE Alletra
HPE’s current storage platform, built on all-NVMe hardware with the ability to scale compute and storage tiers independently. The Alletra MP (multi-protocol) line supports both block and file workloads natively. HPE positions this alongside GreenLake, their consumption-based billing model that converts CapEx to OpEx while keeping data on-premises – essentially cloud economics without the cloud.
The InfoSight predictive analytics engine is a genuine differentiator – it correlates telemetry across the installed base to predict failures before they cause outages. Peer Persistence provides active-active failover for block workloads across two arrays.
HPE InfoSight management interface
Figure 3: HPE InfoSight management interface
Protocols NVMe/FC, NVMe/TCP, iSCSI, NFS, SMB
Key features Independent compute/storage scaling, GreenLake as-a-service consumption billing, Peer Persistence active-active failover, InfoSight predictive analytics
Best for VMware vSphere and Tanzu environments, Kubernetes persistent volumes via CSI, mixed database consolidation, organizations needing cloud OpEx with on-premises data sovereignty
Dell PowerStore
Dell’s all-NVMe unified array, built on the PowerStoreOS platform. PowerStore supports both block (iSCSI, FC, NVMe-oF) and file (NFS, SMB) natively from a single appliance. The AppsON feature lets you run VMware VMs directly on the array’s internal hypervisor – useful for running management tools or lightweight workloads co-located with their data, though it’s a niche capability rather than a replacement for dedicated compute.
PowerStore’s inline deduplication and compression run without significant performance penalty on the NVMe hardware, and the array supports active-active metro clustering between two appliances for zero-RPO failover. Anytime Upgrade lets you non-disruptively swap controllers to the next generation, similar to Pure’s Evergreen model. If you’re a Dell shop already running PowerEdge servers and PowerSwitch networking, the integration and single-vendor support story is the practical draw here.
Dell PowerStore Manager interface
Figure 4: Dell PowerStore Manager interface
Protocols iSCSI, FC, NVMe-oF, NFS, SMB
Key features AppsON embedded VMware hypervisor, inline deduplication and compression, active-active metro clustering (zero-RPO), Anytime Upgrade non-disruptive controller refresh
Best for Dell-standardized environments (PowerEdge, PowerSwitch), mixed block and file consolidation, VMware virtualization, workloads requiring non-disruptive hardware lifecycle management
Block-focused storage (SAN)
If your primary workload is transactional databases, VDI, or anything that needs raw block devices with the lowest possible latency, these are the platforms to evaluate. They’re optimized for random I/O performance and typically connect over Fibre Channel or NVMe-oF fabrics.
Pure Storage FlashArray
One of the fastest all-NVMe SAN platforms on the market. The Evergreen subscription model covers controller upgrades, so there are no forklift replacements. Users on community forums running multi-site deployments report component failures but no service interruptions – the architecture handles hardware faults without downtime in practice, not just in theory.
FlashArray is fundamentally a block storage platform – iSCSI, Fibre Channel, and NVMe-oF are its native territory. Pure has added file services (NFS, SMB) in recent Purity releases, but file is a secondary capability here, not the primary design target. If unified block+file is your primary requirement, look at NetApp or HPE first.
Pure Storage Pure1 AIOps dashboard displaying consolidated performance metrics
Figure 5: Pure Storage Pure1 AIOps dashboard displaying consolidated performance metrics
Protocols NVMe-oF, iSCSI, Fibre Channel (primary); NFS, SMB (available but secondary)
Key features DirectFlash NVMe modules, ActiveCluster zero-RPO active-active replication, SafeMode immutable snapshots (out-of-band, delete-proof), Pure1 AIOps, Evergreen//One as-a-service
Best for Tier-1 Oracle and SQL Server databases, VDI, DevOps and CI/CD persistent storage, SaaS backends requiring guaranteed-SLA latency
IBM Storage FlashSystem
FlashSystem delivers sub-100 microsecond latency with NVMe end-to-end. Its real differentiator is Spectrum Virtualize, which can virtualize and pool storage from 400+ third-party array models alongside FlashSystem nodes – meaningful if you’re consolidating a heterogeneous storage estate with arrays from multiple vendors that you’re not ready to decommission yet.
The tradeoff: complex licensing that typically requires professional services engagement to navigate. Get the full licensing matrix upfront, including data-in-place upgrade costs, replication licensing, and ransomware protection add-ons.
IBM FlashSystem grid dashboard showing multiple managed storage systems
Figure 6: IBM FlashSystem grid dashboard showing multiple managed storage systems
Protocols NVMe/FC, NVMe/TCP, iSCSI, FC
Key features Sub-100 microsecond latency, Spectrum Virtualize (400+ third-party arrays), Safeguarded Copy out-of-band immutable backups, HyperSwap active-active failover, IBM Storage Insights AI monitoring
Best for High-frequency trading and payment processing, IBM i and z/OS mainframe, Oracle and Db2 OLTP, healthcare patient record systems, government classified workloads
Scale-out file storage (NAS)
When your workload is large sequential files – AI training datasets, media production, genomics – you need a platform designed for throughput at scale, not random IOPS. Scale-out NAS adds throughput linearly as you add nodes.
Dell EMC PowerScale
Built on the OneFS operating system (formerly known as Isilon), PowerScale presents a single global namespace regardless of cluster size – from a few nodes to multi-petabyte clusters – with near-linear throughput scaling as nodes are added. This is the platform you find in the world’s largest media studios and LLM pre-training pipelines. It handles massive sequential reads and writes exceptionally well.
Important caveat: PowerScale is not designed for high-IOPS random transactional workloads. If you need a database array, look at the block-focused platforms above. PowerScale’s strength is sustained throughput for large files, not latency-sensitive random I/O.
Dell EMC PowerScale OneFS management interface
Figure 7: Dell EMC PowerScale OneFS management interface
Protocols NFS, SMB, HDFS, S3
Key features OneFS global namespace, CloudPools tiering, SmartDedupe and SmartCompression, SyncIQ async replication
Best for AI and ML training datasets, media production and rendering farms, broadcast playout and archive, EDA design workloads, high-performance home directories
Object storage platforms
Object storage is a fundamentally different paradigm from SAN or NAS. Data is accessed via HTTP/S3 APIs, stored as flat objects with metadata, and scales horizontally on commodity hardware. It’s the right architecture for backups, archives, compliance vaults, and data lakes where you need petabyte-scale capacity at the lowest possible cost per GB. It is not a replacement for block or file storage – the access patterns and latency characteristics are entirely different.
If you’re evaluating object storage, you’re typically comparing against public cloud S3 pricing, not against SAN arrays. The decision drivers are cost per TB at scale, S3 API compatibility, and compliance features like WORM and Object Lock.
Cloudian HyperStore
Enterprise object storage with full S3 API compatibility on standard x86 hardware. Any application built for AWS S3 works without code changes, which makes HyperStore a practical landing zone for S3 workload repatriation. S3 Object Lock with WORM support is validated for SEC 17a-4, FINRA, and CFTC, so the compliance certification work is already done for regulated industries. Multi-site geo-distribution with erasure coding handles DR natively.
Cloudian HyperStore management console
Figure 8: Cloudian HyperStore management console
Protocols S3, REST
Key features S3 Object Lock and WORM (SEC 17a-4, FINRA, CFTC), multi-site geo-distribution with erasure coding, metadata indexing, transparent cloud tiering by age or access policy
Best for Backup and archive (Veeam, Commvault), AI/ML training dataset libraries, compliance and legal hold vaults, cloud repatriation from AWS S3
DataCore Swarm (and Swarm Appliance)
Software-defined object storage deployable on standard x86 hardware or as a purpose-built appliance. Swarm uses content-addressed storage – every object is stored and retrieved by a hash of its content, which means the system self-heals without traditional RAID. When a drive or node fails, Swarm automatically detects the missing replicas or erasure-coded fragments and re-protects the data across the remaining healthy nodes. No manual intervention, no rebuild commands, no RAID controller to worry about.
The architecture scales to billions of objects under a single namespace with no metadata bottleneck – Swarm distributes metadata across the cluster rather than relying on a centralized database. Policy-based lifecycle management lets you define retention, replication, and tiering rules per-bucket or per-object, which is critical for environments like healthcare PACS where different studies may have different retention requirements.
DataCore Swarm management interface
Figure 9: DataCore Swarm management interface
Protocols S3, NFS
Key features Self-healing content-addressed storage, erasure coding with configurable durability, policy-based lifecycle management, single namespace across all nodes
Best for Media and entertainment content archives, healthcare PACS and DICOM repositories, surveillance video retention, compliance vaults
Software-defined storage
Software-defined storage (SDS) runs on commodity x86 servers you already own or can source from any vendor – no proprietary array hardware required. You install the storage software on standard servers with local drives, and the software handles replication, failover, and volume management. The appeal is obvious: lower hardware costs, vendor independence, and the ability to scale by adding commodity nodes rather than buying purpose-built appliances.
The tradeoff is that you own the hardware layer. When a drive or server fails, your team replaces it – there’s no vendor support contract covering the physical infrastructure unless you arrange one separately. For organizations with existing server hardware and Linux/Windows administration skills, this is often the most cost-effective path to highly available shared storage.
StarWind Virtual SAN
Turns internal drives on standard x86 servers into shared, highly available storage with no dedicated array required. Deployed on Windows Server, vSphere, or Proxmox. StarWind creates a synchronous mirror between two or three server nodes, so if one node goes down, the others continue serving I/O with no interruption and no data loss. It’s conceptually simple – take the drives already in your servers, mirror them across nodes, present NVMe-oF or iSCSI targets to your hypervisor.
This is a strong fit for SMB and mid-market environments where buying a dedicated SAN array is overkill but you still need HA storage for virtualization. The operational complexity is genuinely low compared to enterprise arrays.
StarWind Virtual SAN management console showing synchronous mirroring configuration across server nodes
Figure 10: StarWind Virtual SAN management console – Dashboard view
Protocols NVMe-oF, iSCSI, NFS, SMB3
Key features Synchronous two-way and three-way mirroring, automatic failover, native VMware vSphere / Hyper-V / KVM / Proxmox integration
Best for SMB and mid-market VMware, Hyper-V, and Proxmox environments, ROBO HA storage on commodity servers, VDI on tight budgets, DR test environments
DataCore Puls8
Container-native storage built for Kubernetes. Turns local node storage into persistent volumes with built-in replication, snapshots, and automated failover – no external array required. If your environment is Kubernetes-first and you want storage that’s managed through Kubernetes APIs rather than a separate storage management plane, this is the category.
Architecture diagram showing container-native storage with Kubernetes CSI persistent volume provisioning
Figure 11: Architecture diagram showing container-native storage with Kubernetes CSI persistent volume provisioning
Protocols NVMe-oF, FC, iSCSI
Key features Dynamic volume provisioning via Kubernetes APIs, volume replication and automated failover, snapshots, thin provisioning, encryption at rest with KMS support, integrated observability (Prometheus, Grafana)
Best for Stateful databases on Kubernetes (PostgreSQL, MySQL, MongoDB), CI/CD pipelines, AI/ML workloads, standardizing storage across dev, test, and production clusters
DataCore SANsymphony
Software-defined block storage that virtualizes any underlying storage – local disks, existing SANs, or cloud volumes – into a single pool with synchronous mirroring, automated tiering, and sub-millisecond caching. SANsymphony runs on standard Windows servers and presents block storage over iSCSI or Fibre Channel to any host or hypervisor. The core value proposition is taking whatever storage hardware you already have (or can buy cheaply) and turning it into enterprise-grade HA block storage without buying a purpose-built array.
The Windows Server dependency is a consideration – if your infrastructure team is Linux-native, the operational fit may not be ideal. That said, for Windows-centric environments, it integrates naturally with Hyper-V and existing Windows administration workflows.
DataCore SANsymphony management console
Figure 12: DataCore SANsymphony management console
Protocols iSCSI, Fibre Channel
Key features Synchronous mirroring across nodes, automated storage tiering (SSD/HDD/cloud), adaptive caching with sub-millisecond reads, storage virtualization across heterogeneous hardware, CDP (continuous data protection)
Best for Virtualizing and consolidating heterogeneous storage estates, Hyper-V and VMware HA storage on commodity hardware, database workloads needing low-latency caching, extending the life of existing SAN investments
Current market conditions
One supply-side factor to consider in 2026: demand for NAND flash is outpacing supply growth, which is driving broader enterprise adoption of QLC (quad-level cell) flash as a mainstream tier for read-heavy and capacity-oriented workloads. TLC remains the performance tier. If you’re planning a large capacity purchase, lead times and pricing volatility are real procurement risks right now. Lock in pricing early and understand your vendor’s component sourcing.
A pricing factor to watch: according to multiple sources, significant industry-wide price increases are expected effective April 1, 2026. If you’re evaluating new hardware solutions – get current quotes from multiple vendors for the same configuration. If you have prior quotes from earlier procurement cycles, compare them – the delta will tell you whether you’re looking at a genuine supply-driven increase or inflated margins.
The storage market in 2026 rewards specificity. The platforms on this list serve genuinely different workloads, and picking the wrong architecture is more expensive than picking the wrong vendor within the right architecture. Start by deciding which category you need – enterprise array, object storage, or software-defined – then build your shortlist from workload requirements, not brand loyalty.
Run a TCO model with real capacity and growth inputs – not vendor-provided “typical” scenarios. Then validate your top two with a structured POC against production workloads, not synthetic benchmarks. Pay particular attention to licensing: ask for the full matrix including data-in-place upgrades, replication licensing, and ransomware protection costs, because the gap between the base quote and the fully-licensed price is where surprises live.
