Exhibit Options ensures business growth and operational efficiency by building a 2-node high availability cluster with StarWind Virtual SAN (VSAN)
February 13, 2025
Download as PDF
Anonymous
IT Manager
IT Manager
CHALLENGE
Before deploying StarWind Virtual SAN (VSAN), Exhibit Options operated an IT infrastructure built on Microsoft Hyper-V. The company faced challenges with scalability, limiting its ability to adapt to changing demands and workloads.
To improve its IT environment, Exhibit Options required a solution that would enhance scalability, ensure high availability (HA), and provide fault tolerance, all within a cost-effective frameworkFinding a suitable VSAN solution became critical for supporting its growing operations and balancing unpredictable workloads.
StarWind VSAN works well and satisfies our requirements.
IT Manager
SOLUTION
Exhibit Options chose StarWind VSAN because it offered a straightforward and affordable solution to its scalability concerns. StarWind VSAN enabled the company to build a two-node cluster, effectively addressing its need for HA and fault tolerance. The solution allowed Exhibit Options to expand its IT infrastructure seamlessly and manage unexpected workloads efficiently.
With the ability to add additional units, Exhibit Options plans to deploy another two-node cluster powered by StarWind in the future, ensuring long-term scalability and operational resilience.
Inspired by our clients' success? Want to improve business continuity for your critical apps and services?
