Business Continuity vs. Disaster Recovery: What’s the Real Difference?
  • November 6, 2025
  • 21 min read
StarWind Product Manager. Dmytro is an expert in virtualization and storage systems. Specializing in infrastructure design, deployment, and optimization, he provides technical leadership in modernizing IT ecosystems. Dmytro delivers high-authority insights into product development, disaster recovery, and enterprise-scale storage solutions for high-availability virtual environments.
Every modern business runs on digital infrastructure. But the hard truth is that when systems fail (and they always do) the resulting chaos rarely stays contained within the IT department. The consequences ripple across operations, reputation, and revenue, costing more than just money.
Failures are now a daily reality. Cyberattacks, natural disasters, and simple human error are constant threats, with global cybercrime costs projected to reach $10.5 trillion annually by 2025. However, the real danger isn’t the disaster itself, but the lack of a realistic, tested plan to handle it.
This is where the distinction between business continuity and disaster recovery becomes critical. They are often used interchangeably, but they are not the same thing. In fact, one of the biggest mistakes organizations make is letting IT lead a BCDR effort alone.
  • Business continuity is about keeping the business running during a crisis.
  • Disaster recovery is the technical component focused on restoring IT systems afterward.
In this article, we’ll break down each concept, clarify the critical differences, and explain how to build a plan that actually works when you need it most.
What Is Business Continuity?
Business Continuity (BC) is a business-led strategy that answers the question:
“How do we continue to serve our customers and generate revenue when our primary people, processes, or systems are unavailable?”
It’s about keeping the business alive, not just restoring IT.
A strong business continuity plan (BCP) is a living document, not a binder on a shelf. It defines how essential teams, services, and supply chains function when something goes wrong. It forces you to answer tough, practical questions:
  • How does the accounting department run payroll if their primary application is down for 48 hours?
  • What is the manual, “on-paper” process for our healthcare clinicians to continue patient care?
  • What do our customer service reps tell callers when the CRM is offline?
Effective continuity planning is about preserving confidence. It’s driven by business units telling IT what they need, not the other way around. Employees know their roles, leadership has a clear chain of command, and the business continues to function, even in a degraded state.
Key Considerations for Business Continuity
A BCP is not a universal template. It must be tailored to your industry, its regulations, and your organization’s specific operations.
Business Impact Analysis (BIA):
This is the foundation. It’s a collaborative process where you identify mission-critical processes, determine the financial and operational cost of downtime, and get business leaders to define acceptable recovery time and recovery point objectives (RTO/RPO).
Workforce and communications:
The plan must define a crisis communication tree. Who makes decisions? How are employees, customers, and stakeholders informed? It must account for remote work, alternate sites, and clear emergency roles.
Supply-chain dependencies:
Evaluate your third-party and vendor risks. What happens if a key supplier is hit by a disaster? Do you have alternate sourcing plans?
Regulatory and compliance:
For regulated industries like healthcare or finance, the BCP must outline how to maintain compliance during an outage and who is responsible for notifying regulators.
In the real world, the BCP is often managed outside of IT, by a risk management or operations team, with IT acting as a key stakeholder. Standards like ISO 22301 and the NIST framework (SP 800-34) provide excellent, though dry, starting points.
What Is Disaster Recovery?
Disaster recovery (DR) is the technical subset of business continuity. It focuses specifically on restoring the IT systems, applications, and data that the business depends on.
If the BCP defines what the business needs to survive, the DR plan details how IT will deliver the technical means for that survival.
A DR plan details backup locations, replication methods, failover mechanisms, and step-by-step recovery procedures (runbooks). It’s the playbook for getting the technology back online after a failure.
The plan is built to meet two key metrics defined by the business during the BIA:
  • Recovery Time Objective (RTO): How quickly must systems be restored?
  • Recovery Point Objective (RPO): How much data loss is acceptable?
A well-designed DR strategy doesn’t just document how to properly backup. It highlights layers of protection and, most importantly, relentless testing to ensure the recovery processes do actually work.
Key Elements of Disaster Recovery
Backup and Replication:
Redundant data copies across different media and locations (the 3-2-1 rule is a start). This includes immutable or air-gapped copies specifically to combat ransomware.
Failover systems:
Secondary servers or cloud instances ready to take over automatically or manually when primary systems fail.
Documented procedures (Runbooks):
Step-by-step instructions that a technician can follow under extreme pressure at 3 AM. These should be clear, concise, and validated.
Testing and validation:
A DR plan that isn’t regularly tested is worthless paper. Ideally, the testing process should scale from simple file restores to full-scale DC outage simulations. Getting the political and financial approval from C-staff for a full data center failover is a massive challenge itself, but depending on your industry, such intense “combat trials” can be an invaluable and even necessary step to ensure the business can actually survive a disaster.
Key Differences: It’s About Ownership and Scope
While they overlap, the core difference is simple: BC is a business problem, and DR is the technical solution to part of that problem.
Aspect Business Continuity (BC) Disaster Recovery (DR)
Purpose Maintain essential business operations during a disruption. Restore IT infrastructure and data after a disruption.
Scope The entire organization: people, processes, facilities, vendors, and communication. IT infrastructure: servers, storage, applications, and networks.
Ownership Business leadership, operations, or risk management teams. Primarily managed and executed by IT and infrastructure teams.
Objective Keep employees productive, serve customers, and minimize revenue loss. Restore critical technology and data access within the business-defined RTO/RPO.
Examples Activating a call center at a secondary site. Switching to manual, paper-based order processing. Communicating with clients about delays. Failing over a database to a secondary data center. Restoring servers from cloud backups. Isolating a network after a ransomware attack.
The BCDR “Umbrella”
A mature organization understands that BC and DR don’t exist in a vacuum. They are part of a larger resilience framework that starts the moment an incident occurs. This is where the Incident Response Plan (IRP) comes in.
Think of the relationship as a clear chain of command during a crisis:
  • The Incident Response Plan (IRP): Immediate, tactical playbook for identifying, containing, and analyzing an incident.
  • The Business Continuity Plan (BCP): Activated by the IRP, defines how the business continues to operate in a degraded state.
  • The Disaster Recovery Plan (DRP): Called upon by the BCP, detailing how IT restores critical systems.
When you have all three, you have a complete BCDR umbrella.
The IRP handles the immediate chaos, the BCP keeps the business afloat, and the DRP brings the technology back online.
Without this alignment, you end up with IT restoring systems the business doesn’t immediately need, while critical operations remain paralyzed.
Cloud and Hybrid Considerations
Moving to the cloud doesn’t automatically give you a DR plan, instead, it just changes your failure domains.
Here’s what actually matters:
Shared responsibility is a trap
Don’t assume your cloud provider handles your resilience. They secure the cloud, while you are responsible for securing in the cloud. This means you own your data, configurations, identity management, and the responsibility to test your own recovery processes.
High Availability (HA) vs. DR
Using multiple availability zones (AZs) protects you from a data center failure, but not a regional outage, a bad code push, or a ransomware attack. That’s HA. True DR requires replicating to another region or a separate cloud provider.
Automation is non-negotiable
In a crisis, you can’t be manually spinning up servers and configuring networks. Use Infrastructure as Code (IaC) tools like Terraform or Ansible to codify your recovery environment. Your runbooks should be scripts, not Word docs or Confluence pages. Also, automated configuration restores leave much less room for failure than manual re-deploy (and you don’t want any failures on top of the disaster you are trying to recover from).
Watch for surprise bills
Data egress fees during a large-scale recovery can be astronomical. Model and forecast these costs as part of your DR budget. Don’t let a successful recovery lead to a financial disaster.
Identity is a critical failure point
If your identity provider goes down, your entire failover site is useless. Ensure you have redundant authentication paths and a plan to access systems if your primary IdP is offline.
How to Build a BCDR Plan That Doesn’t Fail
BCDR components, processes, and their visualization
Figure 1: BCDR components, processes, and their visualization
Once again, building a plan is “slightly” more than just filling out a template. It’s a cycle of preparation, testing, and learning.
  1. Get the right people in a room. Start with the Business Impact Analysis (BIA). This isn’t an IT survey; it’s a series of workshops with business leaders where you ask: “What breaks first? What costs us the most money per hour of downtime?”
  2. Define realistic recovery objectives. Based on the BIA, negotiate the RTOs and RPOs. The business might want a zero-minute RTO, but they won’t want the multi-million dollar price tag. This is a business decision, not a technical one.
  3. Develop real-world strategies. The plan must include technical recovery steps (failover, restore from backup) and manual business procedures (going to paper, using alternate suppliers, crisis communication scripts).
  4. Establish a clear chain of command. Your plan must explicitly state who has the authority to declare a disaster and who is responsible for what. In a crisis, ambiguity leads to paralysis.
  5. Document for “3 AM”. Keep the plan concise and actionable. Store it in multiple, accessible locations (including offline copies). No one has time to read a 200-page binder during a real outage.
  6. Test. Test. And Test Again. This is the most important step. Run tabletop exercises, test file restores, and conduct full failover drills at least annually. Break things on purpose in a controlled way. A plan is just a theory until it’s been tested under pressure.
BC/DR Stories: Lessons from the Trenches
Success: Banco Santander (2017)
(https://www.newyorkfed.org/medialibrary/media/research/staff_reports/sr1078.pdf )
When Hurricane Maria devastated Puerto Rico, the bank restored 95% of operations within a week while competitors were dark for months. This wasn’t luck.
  • The Lesson: They had geographically distributed data centers and, more importantly, they drilled their BCP quarterly. Everyone knew their role because they had practiced it.
Failure: British Airways (2017)
(https://www.theguardian.com/business/2017/may/31/ba-it-shutdown-caused-by-uncontrolled-return-of-power-after-outage)
A simple power outage at a single data center led to over 700 canceled flights and £80 million in losses.
  • The Lesson: A plan on paper is not a plan. They had DR systems, but a lack of testing and automated failover meant a minor issue cascaded into a global catastrophe. A single point of failure can, and will, take down your business.
Success: GitLab (2017)
(https://about.gitlab.com/blog/postmortem-of-database-outage-of-january-31 )
After an engineer accidentally deleted 300 GB of production data, the team recovered in 18 hours, livestreaming the entire process.
  • The Lesson: Radical transparency built customer trust. But the real success was their culture of documented runbooks and a blameless post-mortem. They analyzed what went wrong and implemented concrete fixes, making the entire system more resilient for the future.
How StarWind Helps Bridge the Gap
A plan is only as good as the tools you use to execute it. StarWind provides the foundation for a practical BCDR strategy.
For Continuous Business Operations:
StarWind HCI Appliance unifies compute, storage, and networking with built-in fault tolerance and synchronous replication, minimizing downtime risks and eliminating single points of failure.
For Fast and Reliable Recovery:
StarWind Backup Appliance acts as both a backup target and recovery platform. NVMe storage enables near-instant recovery and temporary workload hosting during outages.
Business continuity and disaster recovery are fundamental business strategies. BC keeps business running when things go south, while DR brings things back to normal after an outage. When developed in lockstep with business leaders and tested relentlessly, they ensure that when (not if) a disruption occurs, it’s a manageable incident, not an existential threat.
Hey! Found Dmytro’s article helpful? Looking to deploy a new, easy-to-manage, and cost-effective hyperconverged infrastructure?
