Rocco’s Collision Center reduces IT operational expenses by building a hyperconverged infrastructure around StarWind HCA
PUBLISHED/UPDATED: December 16th, 2021
By choosing StarWind, we saved 50% of our StarWind purchase,
the minimum probably $50,000 over a 5-year period.
Director of Information Technology
PROBLEM
Before using StarWind HyperConverged Appliance (HCA), Rocco’s Collision Center had a Scale Computing KVM- and Hyper-V-based hyperconverged infrastructure with hybrid SSDs and no GPU. The existing solution did not provide the company access other than GUI access to create and delete virtual machines (VMs). Rocco’s Collision Center was vendor-locked when researching or resolving any issue. So, getting the freedom of choice and simplicity in IT infrastructure management were the primary points the company wanted to bring in.
SOLUTION
Rocco’s Collision Center chose StarWind HCA primarily over the seamlessness it provides through the easy usability of a GUI if required. Yet the StarWind product still gives the company access to the power tools of Hyper-V and behind the scenes. All this is done with StarWind Command Center, a convenient single-pane-of-glass management and monitoring web UI. There is no longer a vendor lock-in problem since StarWind HCA provided complete freedom of choice in building an IT infrastructure, saving near $50,000 over 5 years at that. In the future when needed to expand or renew its environment, Rocco’s Collision Center plans to continue using StarWind products.
StarWind HyperConverged Appliance Configuration
Appliance Model HCA P-Spec 23
Cluster Size 2 nodes
Cluster density 4U
Servers Dell PowerEdge R740xd
CPU 2 x Intel Xeon Gold 6246R, 3.4 GHz, 16 cores, 32 threads per node
Memory 16 x 32 GB RAM (512 GB total) per node
Cluster Storage Capacity 23 TB of All-Flash storage
Disk Configuration 13 х Dell 1.92TB 6Gbps SATA Mix Use TLC 2.5 SSD S4600 per node
2 x 240GB M.2 SSD (RAID 1) per node
Networking 1 х Intel X520 DP 10Gb DA/SFP+, + I350 DP 1Gb Ethernet, Network Daughter Card
1 х Mellanox ConnectX-4 Lx Dual Port 25GbE DA/SFP Network Adapter
Hypervisor Hyper-V on Windows Server 2019
About the Company
Rocco’s Collision Center is an American company located in Blackwood, New Jersey, that provides auto body and collision repair services.
Company Profile
Automotive industry
Contact Person
Power Your Business With StarWind!
Book Free Online Demo:
Thank you for your application!
We will reply to you shortly.
