Free Webinar
June 6 | 11am PT / 2pm ET
Choose a winning backup strategy
with storing data either in private or in public cloud object storage!
Speaker: Ivan Ischenko, Solutions Engineer, StarWind
Creating Virtual Tape Library device in StarWind Virtual SAN environment
Published: January 24, 2018
INTRODUCTION
Some companies have to adhere to regulatory requirements for tape vaulting, while the backup process requires a smaller backup window.
StarWind Virtual Tape Library (VTL) is a StarWind Virtual SAN feature that eliminates the need for the physical tape by emulating the industry-standard tape hardware and keeping all data on inexpensive, fast and high-capacity spinning disks. This technology is designed for SMB and Enterprise that look for either getting rid of physical tapes completely or accelerate the backup process and add an extra level of protection. Even with explosive data growth, StarWind VTL fits the backup job into reasonable time-frame by accelerating it, so that the process does not overlap with production time.
This guide is intended for experienced StarWind users, Windows system administrators and IT professionals who would like to configure StarWind Virtual Tape Library (VTL). It provides step-by-step guidance on how to create the VTL device that runs on top of the Windows Server 2016.
A full set of technical documentation can always be found here.
For any technical inquiries, please, visit our online community, Frequently Asked Questions page, or use the support form to contact our technical support department.
1. Launch the StarWind Management Console by double-clicking the StarWind tray icon.
NOTE: If the StarWind Service and Management Console already are installed on the server, the Management Console will automatically add the local StarWind instance to the Console tree after the first launch. Then, the Management Console automatically connects to the StarWind Service using the default credentials. To add remote StarWind servers to the Console, press the Add Server button on the control panel.
2. StarWind Management console will ask you to specify the default storage pool on the server you connect to for the first time. Please, configure the default storage pool to use one of the volumes you have designated as StarWind storage earlier. All devices created through the Add Device wizard will be stored on that storage pool by default. Should you decide to use an alternative storage path for your StarWind virtual disks, please, use the Add Device (advanced) menu item.
wp-image-12172
3. Press the Yes button to configure the storage pool. If you require changing the storage pool destination, press Choose path and point the browser to the necessary disk.
4. Select the StarWind server where you wish to create the device.
5. Press the Add Device (advanced) button on the toolbar.
6. Add Device Wizard will appear.
Select Tape Device.
wp-image-12173
Click Next to continue.
Select the Virtual Tape item.
wp-image-12174
7. Specify the Virtual Tape Library location
wp-image-12175
8. Select the Device Model from the drop-down list. You also can fill all slots in the newly created Tape Library with empty tapes.
wp-image-12176
9. Then, provide Target Alias or choose the default one.
wp-image-12177
Click the Create button and view the creation progress.
wp-image-12178
10. Once the creation is completed, click Close.
wp-image-12179
11. Next, create the tape. For this purpose, click on the recently created VTL device and press Create Tape. The new Wizard window appears.
wp-image-12180
12. Enter the path to the tape files location if needed and click Next to continue.
wp-image-12181
13. Specify the Number of Tapes, Tape Type, and other parameters.
wp-image-12182
Click the Create button.
14. The created tape appears in the first slot of the VTL device in the StarWind Management Console.
wp-image-12183
Mounting VTL on the backup server
To pass-through the VTL device to the server, it is necessary to mount the corresponding VTL iSCSI target. In this example, the tape library will be mounted locally on the server.
15. Open Microsoft iSCSI Initiator. Afterwards, navigate to the Discovery tab and press the Discover Portal button.
wp-image-12184
16. Enter the localhost address (127.0.0.1) and press the Advanced button.
wp-image-12185
17. Select Microsoft iSCSI Initiator from the Local Adapter drop-down list and, press the OK button to add the discover portal.
wp-image-12186
18. Open the Targets tab, find the iSCSI target, which corresponds to the StarWind VTL device, and press the Connect button.
19. In the appeared window, uncheck the Enable multi-path option and press the Advanced button.
wp-image-12187
Set a Local adapter as the Microsoft iSCSI Initiator, specify 127.0.0.1 / 3260 as a Target portal IP, and press the OK button twice to connect to the target.
wp-image-12188
Now, the VTL iSCSI target is listed as Connected.
Installing tape library drivers
It’s recommended to install the latest update of the HP driver. The driver for HP MSL8096 can be downloaded here: HPE StoreEver Tape Drivers for Microsoft Windows. The current version (4.2.0.0) supports Windows Server 2016. HP drivers must be installed on the host where StarWind VTL device is mounted via iSCSI. In our example, a local host is used.
1. Extract the previously downloaded driver (Step 4) and launch cpqsetup.exe
wp-image-12189
2. Select All and click Install.
wp-image-12190
3. Once the drivers are installed, you will see Hewlett Packard MSL G3 Series library (x64 based) in the Medium Changer devices.
wp-image-12191
Now, everything is ready for adding the tape library to backup software.
CONCLUSION
The StarWind VTL seamlessly integrates into the existing infrastructures and allows the backup process to fit the backup window that not only meets the regulatory requirements but also enables to reduce the backup costs. At the same time, system performance remains stable by increasing the speed of the backup process. StarWind VTL works great with Veeam Backup and Replication and other backup solutions.
