The Performance tab displays graphs of the system resources used on the StarWind server. The period option can display graphs for Last Hour and Last 24 Hours.
Use the Performance Counter list to select the monitoring approach and the Performance Source to select what exactly has to be displayed on the graphs.
Performance graphs can be saved in the .bmp format by using the Save option.
