To synchronize a disk that is a part of replication device:
1. Right-click the replication device and select Synchronization from the shortcut menu.
2. Select the node you want to use as a synchronization source.
Note: The wrong direction of the device synchronization may cause data loss.
3. Click Synchronize to start the synchronization process.
