Hi there,
I have a win2003 64 bit target exporting 8TB in iscsi targets.
We are going to perform some changes and wanted to ask here if is there any benefit in terms of performance to export the iscsi targets to my two xenservers as RAW devices instead of formatting them in the target as ntfs, creating a .img file and then exporting the img.
my first answer will be that since xenserver will use lvm over iscsi, then exporting as raw devices from the starwind server will yield better performance as the disks are being accessed directly.
comments?
