I have a little problem trying mount a Raid5 with Starwind, but I dont know if its the initiator or Starwind iscsi.
I have a Hyper V R2 with 2k8 Server Enterprise with Starwind iSCSI, then I make 3 virtual hard disk with basic configuration, allowing multiple conections as cluster.
Then in other Hyper V R2, I conect the 3 virtual hard disk with Microsoft Initiator, and they appear correctly on Disk Manager.
The next step its create Raid5 from that 3 Hard Disk, and them are created correctly till I restart the Hyper V.
When I restart it, on the Disk Manager appear the 3 Hard Disk with errors trying to do the Raid 5, but they arent working.
If I restart the Hyper V without make Raid 5, the 3 Hard Disk after restart, are working fine as simple volumn.
So I would to know if the problem its from Starwind that cant create correct Raid5, or from Microsoft Initiator... I tryed with Starwind Initiator too, but I get the same error...
Well, I hope you can help me.
