I am testing out StarWind 3.1.4 on a windows 2003 server and I am haveing alot of trouble just geting off the ground with it. The first thing I try to do is switch the authentication to anonymous and the whole thing just dies. The service stops and you have to start it manually and the authentication never changes. If you try this several times eventually you get locked out all together with Invalid auth method. I change the prefs to login with all diffrent type of auth and nothing works. The only way to fix it is to remove and reinstall the app.
Does not look good for the trial of this software as I have been at this for 2 days and my trial is running out. I was really hoping there was another solution than having to buy Microsoft Storage server.
Any help would be great.
