mooseracing wrote:As the title suggests I am having some issues about a week into the upgrade of 5.6. All of a sudden when my primary is online none of my VM's will respond that are on the iSCSI. As soon as I shutdown the primary and the partner takes over everything works great. My partner can't run everything very well currently, I'm waiting for parts to get here to build a decent one.
I thought maybe there might have been some corruption so the last time I brought the primary up I did a full sync after the fast, but that didn't help any.
I am using this in a Srv 2008 Cluster with VM's on the iSCSI w/HA. Both of my cluster servers show connected to the iSCSI target when this problem occurs.
Idears?
camealy wrote:Is the roll back to 5.5 as simple as stopping the service on one side, installing 5.5 and re-synching? Will 5.5 install on top of 5.6 or do you have to uninstall first?
@ziz (staff) wrote:camealy wrote:Is the roll back to 5.5 as simple as stopping the service on one side, installing 5.5 and re-synching? Will 5.5 install on top of 5.6 or do you have to uninstall first?
It can be installed on top.
Install on one side, sync, then install on second side and sync.
mooseracing wrote:@ziz (staff) wrote:camealy wrote:Is the roll back to 5.5 as simple as stopping the service on one side, installing 5.5 and re-synching? Will 5.5 install on top of 5.6 or do you have to uninstall first?
Yep, this is what I did. It did Fast syncs and not Fulls if you are wondering that as well.
Users browsing this forum: No registered users and 3 guests
