StarWind Enterprise Server
Request a Quote
Feel free to contact us:
USA and LATAM:
1-617-449-7717
EMEA and APAC:
+44(0)2071936727
+44(0)2071936350
+33(0)977197857 (French)
+49-1715109103 (Germany)
Voice Mail:
1-866-790-2646
Email:
sales@starwindsoftware.com
perfomance
iSCSI Target for Microsoft Windows.
perfomance
Postby slavik » Wed May 12, 2010 12:02 pm
hello
i have strange very low perfomance, i have 1 esxi 4.0u1 (build 244038) on sun x4100 and starwind (5.3.0.1310) at windows 2003r2 x64 running on sun x4600, when i xmit data over gigabit copper i have about 3 meg per second even if device is ramdrive :shock:
slavik
Re: perfomance
Postby Constantin (staff) » Thu May 13, 2010 8:46 am
test your network please using iperf or NTTTCP
Constantin Videnski
StarWind Software Support Department
support at starwindsoftware dot com
Constantin (staff)
Re: perfomance
Postby slavik » Thu May 13, 2010 9:07 am
already, looks like this is esxi4 problem instead of starwind bug.
good perfomance inside vm with microsoft initiator, and poor from host.
slavik
Re: perfomance
Postby Constantin (staff) » Thu May 13, 2010 9:23 am
OK... What build of ESX do you use and what NICs?
Constantin Videnski
Constantin (staff)
Re: perfomance
Postby slavik » Thu May 13, 2010 12:22 pm
"...esxi 4.0u1 (build 244038) on sun x4100..."
onboard 1 intel pro 1000 mt dual port server, broadcom n/c
slavik
Re: perfomance
Postby Constantin (staff) » Mon May 17, 2010 9:00 am
That`s strange... Have you find ant reason of this problem?
Constantin Videnski
Constantin (staff)
Re: perfomance
Postby slavik » Mon May 17, 2010 10:09 am
no, i suggest this esxi4 perfomance problem is irq-flood related. Because i found similar problem with iscsi target based on freebsd (istgt). But there is much less perfomance penalty, native 30MB/s down to 10MB/s via gigabit iscsi, with starwind speed penalty native 90MB/s down to 3MB/s.
slavik
Re: perfomance
Postby slavik » Wed May 19, 2010 12:13 pm
up: this (3MBps) poor perfomance didn't stable, sometimes it raises up to 15-50MBps.
anyway this is much less than raw perfomance from SAS stripe (85 to 110 MBps)
slavik
Re: perfomance
Postby anton (staff) » Wed May 19, 2010 3:22 pm
If you have the same degradation picture with other iSCSI target I'd suggest you to double-check ESX(i) iSCSI initiator settings and if approved OK check other hardware.
Re: perfomance
Postby slavik » Thu May 20, 2010 4:05 am
anton, what settings exactly you suggest to check?
hardware is okey, this was checked already, and indirectly indicated by fact that inside VM iscsi initiator works much better
slavik
Re: perfomance
Postby Max (staff) » Thu May 20, 2010 3:56 pm
slavik
Please try connecting ESXi host directly to the StarWind server using a straight connection and reproducing the issue.
Max Kolomyeytsev
Max (staff)
Re: perfomance
Postby slavik » Fri Jun 11, 2010 5:55 am
max, "good perfomance inside vm with microsoft initiator, and poor from host." - this means if initiator inside VM i has nice speed, so I suggest this bug does NOT network related, but i can test straight connection speed next week
slavik
Re: perfomance
Postby Constantin (staff) » Fri Jun 11, 2010 1:12 pm
So, please inform about result of test (direct connection w/o switch) in datacenter.
Constantin Videnski
Constantin (staff)
Return to StarWind
Who is online
Users browsing this forum: No registered users and 3 guests
