StarWind Enterprise Server
Request a Quote
Feel free to contact us:
USA and LATAM:
1-617-449-7717
EMEA and APAC:
+44(0)2071936727
+44(0)2071936350
+33(0)977197857 (French)
+49-1715109103 (Germany)
Voice Mail:
1-866-790-2646
Email:
sales@starwindsoftware.com
Moving iSCSI Targets
iSCSI Target for Microsoft Windows.
Postby dmmattix » Mon Jun 27, 2011 9:34 pm
We have a StarWind implementation that I need to migrate existing targets (serving VMWare VMs) from one disk array to another on Windows Storage Server 2008. Since this is in production and I really don't want to get into something without knowing where I am going and how to get there I thought I would ask. Is this a simple task or fairly convoluted? Any documentation out there on how to do this?
Mike
dmmattix
Re: Moving iSCSI Targets
Postby anton (staff) » Tue Jun 28, 2011 4:59 am
You need to configure extra storage pool and use Storage vMotion to move your VMDKs and VM configuration files from one place to another. No downtime is required. We do have HOWTOs in draft so please drop us a message to support to gain access to pre-release ones.
P.S. If you're with Microsoft you should use equivalent technology called Live Storage Migration. It does represent minimal VM downtime however...
Postby dmmattix » Tue Jun 28, 2011 3:29 pm
Anton,
Thanks for your response. I have vSphere Essentials Plus which while it has vMotion I do not believe it has Storage vMotion but with VMWare licensing who can really tell. I am developing a strategy to NOT have to move the targets because it does seem to be a bit of a hassle to move them.
Mike
dmmattix
Postby anton (staff) » Tue Jun 28, 2011 7:12 pm
I'm not sure I've got you correctly... In your first post you told us you need to move VMs from one disk array to the other and now you tell us you're developing a strategy with no move idea in mind. How do you expect this to work? :) If you expect StarWind performing Storage vMotion on it's own then I'm afraid this is not possible (either now or ever). Maybe you could put a little bit more light on your task and all circumstances? Thanks!
dmmattix wrote:Anton,
Mike
Postby clayton@mcc911.org » Tue Jul 05, 2011 8:06 pm
When you say Move targets? Do you mean move the Starwind IMG to a different hard dive - array?
That is fairly easy but you cant do it on line. You have to force remove the target and then copy the file to its new location and then add the target back preserving the existing data.
As for moving VMs from one target to the other. You don’t have to use vmotion storage IF you can turn them off, if they are off just use the migrate function.
You ver of vcenter does not have vmotion storage. if you MUST move a vm from one data store to another hot, i will let you in on a little secrete,, the demo key has FULL function, so you just unregister your key use the demo key, move you vm with vmotion storage and then put your key back, but move fast you only have 120 to do it after you remove your key lol.
clayton@mcc911.org
Postby anton (staff) » Thu Jul 14, 2011 4:05 pm
1) Yes, you cannot move StarWind own storage to some other location. We'll do it one day but it's not going to happen tomorrow.
2) Yes, if you can put VM down you can just copy/delete content. If you cannot afford to put VM down then Storage vMotion is the only way to go. Microsoft Live Storage Migration still brings minimal downtime. Hope they are going to fix it one day...
clayton@mcc911.org wrote:When you say Move targets? Do you mean move the Starwind IMG to a different hard dive - array?
Return to StarWind
Who is online
Users browsing this forum: No registered users and 3 guests
