StarWind Enterprise Server
Request a Quote
Feel free to contact us:
USA and LATAM:
1-617-449-7717
EMEA and APAC:
+44(0)2071936727
+44(0)2071936350
+33(0)977197857 (French)
+49-1715109103 (Germany)
Voice Mail:
1-866-790-2646
Email:
sales@starwindsoftware.com
5.8 install/upgrade problem
iSCSI Target for Microsoft Windows.
Postby jimbul » Mon Jan 23, 2012 4:14 am
Dear all,
We're currently running Starwind 5.7 in HA across 2x HP G6 DL370's. Both sides have 12gb ram, and are running great as far as i can see.
In order to benefit down from both nodes down protection and faster sync etc. I'm keen to move to 5.8, but when i run the installer (with admin rights, right clicked or from admin cmd prompt), i receive the following:
"An error occured while trying to replace the existing file: DeleteFile failed; code 5." (this is to replace the starwind service)
The service is stopped, completely and is not in memory.
We're running w2k8 R2 sp2 and up to date with updates.
Can anyone let me know what i'm doing wrong or how to resolve this?
Many thanks,
Jim.
jimbul
Re: 5.8 install/upgrade problem
Postby lohelle » Mon Jan 23, 2012 8:27 am
I had the same problem. I just renamed the existing exe and setup will continue.
lohelle
Postby anton (staff) » Mon Jan 23, 2012 11:33 pm
This one is known issue and we'll re-pack installation with this sorted out ASAP. Sorry for this!
Postby Alex (staff) » Tue Jan 24, 2012 9:46 am
lohelle, jimbul,
We have recently found out that the issue shows up when Windows Event Log window is open during installation. Event Log loads strings from StarWindService.exe file, and locks it. The problem can be resolved by closing Windows Event Log window.
This issue will be fixed in a few days.
Alexey.
Alex (staff)
Postby jimbul » Tue Jan 24, 2012 10:39 am
hi there. event log wasnt open (not in an rdp session either) but we do have scom agents on the servers. is it possible they could also cause this behaviour as they gather events?
cheers,
jim
jimbul
Postby Alex (staff) » Tue Jan 24, 2012 10:43 am
Jim,
Yes. I suppose, the agents are using the same engine as standard events viewer.
Alexey.
Alex (staff)
Postby Max (staff) » Tue Jan 24, 2012 10:48 am
This is possible since they use the same tools to obtain information from the OS. Did you have any chance to reproduce the issue with the agents disabled?
Max Kolomyeytsev
Max (staff)
Postby jimbul » Thu Jan 26, 2012 3:31 am
Hi there, with agents disabled we see the same issue, also if i rename the installation file as suggested earlier we see the same issue.
Aside from UPS monitoring software the only other stuff on the box is the HP Proliant support pack and windows updates.
Many thanks,
Jim
jimbul
Postby Anatoly (staff) » Thu Jan 26, 2012 4:50 pm
Can you confirm that you have stopped StarWind service manually?
Could you kindly ensure that it stoped? It can be done by checking if you can see in the log string
%approximate time when service is stopped% Srv: Shutdown completed.
and monitoring Service Manager
StarWind Software Support Department
Postby jimbul » Fri Jan 27, 2012 1:43 am
Anatoly (staff) wrote:Can you confirm that you have stopped StarWind service manually?
Hi thanks for checking:
Yes i can confirm the above, completely shut down according to both services and the starwind log:
1/27 9:20:11.119 1220 Srv: Shutdown completed.
Same response when updated package is run.
We're running 5.7.1721 with 3 HA targets and one non-ha.
Cheers,
Jim
jimbul
Postby jimbul » Sat Jan 28, 2012 7:54 am
Should i open a support case all? No problem if so.
jimbul
Postby anton (staff) » Mon Jan 30, 2012 10:47 am
I've asked to open support ticket for you so no need to bother. Thank you!
jimbul wrote:Should i open a support case all? No problem if so.
Postby gstephenson » Wed Feb 15, 2012 9:26 pm
Did this issue get resolved? What was the solution? I had this problem when I went from v5.6 to v5.7. I am hoping to avoid it going to v5.8.
gstephenson
Postby jimbul » Wed Feb 15, 2012 11:43 pm
gstephenson wrote:Did this issue get resolved? What was the solution? I had this problem when I went from v5.6 to v5.7. I am hoping to avoid it going to v5.8.
anatoly called me to assist, but I didn't read the instructions and the upgrade requires downtime so we were not able to proceed(rtfm....) Will rearrange and get them on the phone when I do our London site in a few weeks.
jimbul
Postby anton (staff) » Fri Feb 17, 2012 12:34 pm
NP
Please take your time and we'll be happy to help when you'll be done.
Return to StarWind
Who is online
Users browsing this forum: Google [Bot] and 3 guests
