StarWind Enterprise Server
Request a Quote
Feel free to contact us:
USA and LATAM:
1-617-449-7717
EMEA and APAC:
+44(0)2071936727
+44(0)2071936350
+33(0)977197857 (French)
+49-1715109103 (Germany)
Voice Mail:
1-866-790-2646
Email:
sales@starwindsoftware.com
Feature requests
iSCSI Target for Microsoft Windows.
Feature requests
Postby lohelle » Tue Jan 24, 2012 9:15 am
created a new topic as requested:
Feature requests:
- Vaai support -reclaim of space on dedupe devices when deleting files in VMFS, offload esxi hosts when cloning and svmotion
- Dedupe support for HA-devices
- Tool to "clean" target dedupe-device for unused dedupe blocks
- Change sync-channel NIC/IP for HA-targets - change ip, nic, mpio etc
- Sync channel bandwidth limit - possible to change with target online (easier than the priority slider in many cases)
- pause / resume on sync (HA)
- multi-lun support for HA-targets
- When resizing HA target, prefill with existing size
- Dedupe-device resize (same as for HA)
- auto-tiering (SSD/SAS/SATA)
- relocate device disk files, online if possible - Would be nice to move files to a temporary partition, recreate the RAID , then move the files back. All with the target online
- notify client when changes on target (when I add a lun on a Dell MD3220i, the LUN is visible on the ESX host without rescan of the iscsi adapter. I do not know if this is because vSphere has built in extended support for these types of targets)
***- RAM-disk on one of the HA-nodes. Recreated automaticly and synced after reboot. Not as secure as disks on both sides, but IO for reads would be EXTREME, and writes would be fast with proper writeback-cache for the other node.
I use SSD's on one node and SAS on the other. I use fixed paths in vSphere pointed at the SSD's. This way all hosts read with VERY high IOPS from the SSD-disks, and the shorts bursts of writes are usually handled by the cache on node 2. RAM-disks would be even faster than SSD for datastores that need HIGH IOPS.
I just bought 128GB DDR3 ECC REG memory for $1300 (8GB modules), so quite large RAM-disks would be within limits for most customers? My quad 8-core Opteron 6000 series server support 32 of these modules, and many other servers do.
lohelle
Re: Feature requests
Postby anton (staff) » Thu Jan 26, 2012 1:01 am
See my comments below after *** mark.
lohelle wrote:created a new topic as requested:
Feature requests:
*** On the way. V6 will include both VAAI suport and automatic space de-allocation for dedupe and thin provisioning.
*** On the way. V6 will include it.
*** On the way. V6 will include add-on to VSS service providers you're expected to run on client side. They will also "free" space.
*** You mean on the fly or what?
*** Do you mean sync channel bandwidth throttling?
*** OK
*** Already under way. V6 or post-V6 (not sure yet).
*** What do you mean here?
*** Can only grow them via LUN increment. On the way (V6).
*** On the way but pretty early. Post-V6.
*** That's what whole HA concept is for. Put device down, do what you do and re-sync.
*** We'll check is this possible for us...
*** You can create RAM disk now and just re-sync the thing from the very begining. As RAM should be small and fast not going to take a lot of time.
*** Also nothing from our side to make it working.
Postby lohelle » Thu Jan 26, 2012 9:23 am
Yes, I mean change that on the fly.
Yes, bandwidth throttling in Mbits/s
When I want to resize a HA target I'm prompted to enter new size. Maybe the existing size should be prefilled or at least shown.
And the RAM-disk + HA suggestion. I see no choice to use RAM-disk on one node. I ment using Starwind's RAM-disk as one node, automaticly syncing with the disk target on the other node after reboot.
lohelle
Postby anton (staff) » Thu Jan 26, 2012 10:08 am
1) Not sure about changing this stuff on the fly as there are issues.
2) OK, B/W throttling is fine. We'll add this (control, now it's automatic).
3) OK, so size is GUI issue.
4) OK, RAM disk for HA is fine.
Postby lohelle » Thu Jan 26, 2012 11:13 am
Thank you for the feedback!
I really like the new 5.8 features, so great work! :)
Really looking forward to the 6.0 release!
lohelle
Postby anton (staff) » Thu Jan 26, 2012 11:09 pm
Hope to see you on V6 beta fest before actual release :)
lohelle wrote:Thank you for the feedback!
Postby lohelle » Thu Apr 12, 2012 10:14 am
I have a cool (I think) feature request now that 3-node HA is coming.
How about making it possible to use RAMDISK as one of the nodes? The partner device will need to be automaticly recreated after reboot then..
I could have a 60GB SSD on two nodes and a 60GB RAMDISK on the third, then use fixed path to the RAMDISK (10GbE) to have enormous IO potensial. If the node go down, one of the SSD's will take over. But then when the RAMDISK-node is up again (and synced), this path will be active again.
I have at least one database where this would be perfect (mostly reads).
If we have to use writeback-cache on the SSD-target of 60GB (to cache the entire target), this would require 60GB of extra RAM on both/all nodes.
lohelle
Postby anton (staff) » Thu Apr 12, 2012 10:24 am
I don't see any stoppers here.We'll check what could be done and when. Thank you for your suggestion!
Postby Alex (staff) » Fri Apr 13, 2012 12:08 pm
We have examined the scenario with 3 nodes and RAM disk, and we've got another idea.
You can set different cache sizes for two HA nodes. Cache modes must be equal, but cache sizes can vary.
So you can set up 64MB cache for one node and 60GB for the other node.
It can be done now by editing cache size value for the HA ndoe device in starwind.cfg file (restart service after editing the file).
Most likely we will add this feature to GUI wizard for HA in the next version of StarWind iSCSI SAN.
Alexey.
Alex (staff)
Postby lohelle » Sun Apr 15, 2012 2:15 pm
OK! Great! :)
Btw, would it be possible to "force" the node with large cache to "read" the entire image. So that the intire target is cached as fast as possible?
lohelle
Postby anton (staff) » Sun Apr 15, 2012 2:56 pm
Yes, but it's not going to make any good to you unless you're doing mostly reads and not writes.
lohelle wrote:OK! Great! :)
Postby lohelle » Sun Apr 15, 2012 2:59 pm
Yepp! But it will help VERY MUCH on databases where applications is reading like crazy generating reports etc. :=)
lohelle
Postby anton (staff) » Tue Apr 17, 2012 4:40 pm
We'll do it! :)
Return to StarWind
Who is online
Users browsing this forum: Google [Bot] and 3 guests
