Hi, I just installed Starwind 5.7 as SAN target to my 4 host esxi 4.1u1 cluster.
However, I've been experiencing frequent iscsi connection drop on the esxi side, as you can see in log, the target quickly reconnect themself, the device latency on esxi datastore monitoring is around ~500ms which is terrible, also the queue depth often drop from 128 to 80.
Successfully restored access to volume 4e6dafd4-
109d8400-e082-842b2b4dfe7e (VMSTORE(S))
following connectivity issues.
info
9/12/2011 3:49:11 AM
10.0.0.20
Issue detected on 10.0.0.20: ScsiDeviceIO: 2365:
Failed write command to write-quiesced partition
eui.79207204787fc07c:1 (0:03:40:39.629
cpu3:5282)
warning
9/12/2011 3:49:09 AM
10.0.0.20
On starwind side I've applied all recommended tcp settings and hosts are all using mpio over 6 Gigabit port. I enabled write-through cache with 1000mb cache and 5000ms expiration time, I also raised max queue from 64 to 128, since I saw the drop.
please advise where I did wrong and how to prevent the periodical drop.
