Im currently building/testing an "el cheapo" san for ESXi, and so far, i think the performance is quite ok
This is a test from a VM running Windows Server Enterprise 2008 R2 on an ESXi local datastore, using MS iSCSI initiator
As you can see it`s pretty good.
The problem is, when i use the ESXi initiator, i format the lun as vmfs, then create a vm/disk inside this datastore, i get this.
Read result is totally wrong according to network stats, it's about 25 MB/s
Just terrible, what could be the reason of this massive underperformance?
I have a dedicated gigabit switch for iSCSI traffic, using 9K jumbo frames on switch, nics, vmkernels, vmswitchs,
Target server is a xeon 3040, 8 GB ram, two Gb intel nics for iSCSI (teaming), running Windows Server Enterprise 2008 R2
Initiator (ESXi) is a dual xeon 5506 supermicro, using 1 nic for iSCSI
