StarWind Enterprise Server
Request a Quote
Feel free to contact us:
USA and LATAM:
1-617-449-7717
EMEA and APAC:
+44(0)2071936727
+44(0)2071936350
+33(0)977197857 (French)
+49-1715109103 (Germany)
Voice Mail:
1-866-790-2646
Email:
sales@starwindsoftware.com
Can't Change Network Interface.
iSCSI Target for Microsoft Windows.
Postby krisjturn » Tue Sep 20, 2011 1:38 am
Just downloaded and installed the free version for testing. I have a seperate VLAN for iSCSI traffic and I am trying to change or add to the SErver Settings/Network section. I see the local loopback IP address is enabled. I click Add and select the IP for my iSCSI connection. I have the correct ports and the Enable Network Interface is selected. I hit ok and the screen returns to the Network window without my newly added network. I check the log fils and keep seeing this when I try adding:
9/19 18:06:51.816 1970 error: assertion failed: c:\_starwind\_v5\starwind\service\common\fn_common.cpp:28 (isEmpty())
9/19 18:06:51.816 1970 Srv: bind() to 192.168.10.12:3260 failed: An attempt was made to access a socket in a way forbidden by its access permissions. (code: 10013).
9/19 18:06:51.816 1970 Srv: Waiting for iSCSI connections at 127.0.0.1:3260 ...
9/19 18:07:11.160 16cc conf: Variable 'listen' is set to '*,'.
I have this installed on
Windows Server 2008 R2 Datacenter with SP1.
36 GB Ram
64 Bit OS
Single Intel Xeon CPU E5506 @ 2.13 GHz
krisjturn
Re: Can't Change Network Interface.
Postby krisjturn » Tue Sep 20, 2011 2:14 am
I fixed it by uninstalling rebooting and reinstalling again.
krisjturn
Postby anton (staff) » Tue Sep 20, 2011 10:15 am
Looks like a firewall issue to me.
Postby krisjturn » Tue Sep 20, 2011 4:48 pm
I think it was also related to the fact that I had the Microsoft iSCSI Target software installed. So a uninstall of both programs and a reboot fixed it.
krisjturn
Postby anton (staff) » Tue Sep 20, 2011 8:44 pm
Port conflict. By default both apps try to bind to port 3260. There's a way to make StarWind use other TCP port so both targets should in theory co-exist on the same machine but getting rid of MS target is a better idea :)
krisjturn wrote:I think it was also related to the fact that I had the Microsoft iSCSI Target software installed. So a uninstall of both programs and a reboot fixed it.
Postby localh0rst » Tue Nov 15, 2011 3:17 pm
sorry for replying this old Thread, but where can I find how to change the default port of Starwind? I have MS iSCSI-Target running and want to test the performance with a parallel Installation of Starwind. Thanks a lot for your help!
localh0rst
Postby Constantin (staff) » Wed Nov 16, 2011 11:28 am
We don`t recommend to run tests when both targets are installed. We recommend to disable MS iSCSI target service and best option is to uninstall it.
The reason for it is that you can face with performance issues during testing.
Constantin Videnski
StarWind Software Support Department
support at starwindsoftware dot com
Constantin (staff)
Return to StarWind
Who is online
Users browsing this forum: Google [Bot] and 3 guests
