by morristownperson » Mon Jun 13, 2011 2:39 pm
here is initiator log
the target device is a seagate black armour and I am struggling finding a lg
the problem is I cannot attach file. this system seems to dis allow all extension !!!
here is the bit where I have enabled the device and it has found the target , but then wont talk
i think you are correct for the NAT
Also the server is on my RS farm , so it has a PIX which we run through a CP
I can use the Vyetta at another of our farms
john
6/13 07:32:15.856 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 07:32:16.184 CStarPortAPI::InsertiSCSIDevice: Session failed, status == 121 !
6/13 07:32:16.184 >> CStarPortAPI::~CStarPortAPI()
6/13 07:32:16.184 CWPPiSCSITargetSelection::CreateDevice: Exception caught: The semaphore timeout period has expired.
6/13 07:32:16.184 CWPPiSCSITargetSelection::CreateDevice: Failed to connect to create iSCSI device using TargetName=iqn.1992-09.com.seagate:douglas1, IP:0xC0A8010C, Port:3260
6/13 07:32:16.184 CWPPiSCSITargetSelection::CreateDevice: Creation of the iSCSI device failed with all the addresses supplied by the server.
6/13 07:32:16.184 CWPPiSCSITargetSelection::CreateDevice: Exception caught: Creation of the iSCSI device failed with all the addresses
6/13 07:32:16.262 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 07:32:16.668 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 07:32:17.073 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 07:32:17.479 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 07:32:17.884 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 07:32:18.290 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 07:32:18.696 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 07:32:19.101 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 07:32:19.507 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 07:32:19.912 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 07:32:20.318 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
6/13 07:32:20.724 CMainFrame::PoolingServiceEvents: Event checking failed, status == 2
