StarWind Enterprise Server
Request a Quote
Feel free to contact us:
USA and LATAM:
1-617-449-7717
EMEA and APAC:
+44(0)2071936727
+44(0)2071936350
+33(0)977197857 (French)
+49-1715109103 (Germany)
Voice Mail:
1-866-790-2646
Email:
sales@starwindsoftware.com
IP connectivity lost timeout question...
iSCSI, FCoE and AoE Initiator for Microsoft Windows.
Postby Bill.French » Tue Aug 21, 2007 2:22 am
I'm using starport on w2k3 to connect via iSCSI to another server running starwind. If IP connectivity is lost between the two, there is a significant pause before the disk is reported as "failed" to the OS - is there a way to control the timeout if there's a loss in connectivity? I actually want to make the timeout shorter, although I could see a case for making it longer than the default for different circumstances. I'm honestly not sure if the timeout issue is on the OS or Starport side.
Here's what I'm trying to accomplish, all of this in on a VM in ESX3 :
C: - on EMC FC SAN
O: - mirrored dynamic disk, mirroring a virtual disk residing on the EMC FC SAN and the Starport iSCSI device.
It actually all works and performs really well for my scenario here in all my testing, I just wish a loss in connectivity would fail the mirror faster than it does. Presently the server kind of hangs for 30 secs or so (feels like an eternity) before failing the mirror and continuing on its merry way with the remaining good disk (that's on the FC SAN).
Anyway, thank you -- I have really enjoyed working with these products, it is rare these sorts of things are "pleasurable" to work with.
Bill.French
Re: IP connectivity lost timeout question...
Postby Val (staff) » Tue Aug 21, 2007 10:09 am
Bill.French wrote:I'm using starport on w2k3 to connect via iSCSI to another server running starwind. If IP connectivity is lost between the two, there is a significant pause before the disk is reported as "failed" to the OS - is there a way to control the timeout if there's a loss in connectivity? I actually want to make the timeout shorter, although I could see a case for making it longer than the default for different circumstances. I'm honestly not sure if the timeout issue is on the OS or Starport side.
C: - on EMC FC SAN
The iSCSI session reconnect timeout can be tuned via the following registry key:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\StarPort\Parameters\iSCSI], ReconnectTimeout = 30 (by default)
But do not set the timeout too short (1-3 seconds) as it may fail ever good connections in some cases.
Valery
Val (staff)
Postby Bill.French » Tue Aug 21, 2007 12:51 pm
Excellent, thank you. Do you know: does changing the key require a reboot?
Thanks, --Bill
Bill.French
Postby Val (staff) » Tue Aug 21, 2007 2:30 pm
Bill.French wrote:Excellent, thank you. Do you know: does changing the key require a reboot?
Thanks, --Bill
Hi Bill,
Yes, it requeres rebooting the machine if any devices are connected by the StarPort driver.
If the driver is idle, you can safely disable and re-enable it in the Device manager to apply the new settings.
Valery
Val (staff)
Return to StarPort
Who is online
